Liste de codes Samsung
Message Liste de codes Samsung Répondre en citant
je pense que ça peut-être utile pour certain :
Ceux soulignés en vert fonctionnent. N'hésitez pas a faire parvenir vos essais.
*#5239870*#=menu Admin
*#1234#=Firmware Version.
*#2222#
= H/W Version.
#197328640# =test et update camera
*#8999*8376263#=
All Versions Together.
*#8999*8378#
= Test Menu.(marche pas)
*#4777*8665#
= GPSR Tool.
*#8999*523#
= LCD Brightness.
*#8999*377#
= Error Menu.
*#8999*327#
= EEP Menu
*#8999*667#
= Debug Mode.
*#92782#
= PhoneModel. (Wap)
#*5737425#
= JAVA Mode.
*#2255#
= Call List.
*#232337#
= Bluetooth MAC Adress.
*#5282837#
= Java Version.(marche pas)
#*4773#
= Incremental Redundancy.
#*7752#
= 8 PSK uplink capability bit.
#*7785#
= Reset wakeup & RTK timer cariables/variables.
#*7200#
=Tone Generator Mute.
#*3888#
= BLUETOOTH Test mode.
#*7828#
= Task screen.
#*#8377466#
= S/W Version & H/W Version.
#*2562#
= Restarts Phone.
#*2565#
= No Blocking? General Defense.
#*3353#
= General Defense, Code Erased.
#*3837#
= Phone Hangs on White screen.
#*3849#
= Restarts Phone.
#*3851#
= Restarts Phone.
#*3876#
= Restarts Phone.
#*7222#
= Operation Typ: (Class C GSM)
#*7224#
= !!! ERROR !!!
#*7252#
= Operation Typ: (Class B GPRS)
#*7271#
= CMD: (Not Available)
#*7274#
#*7337#
= Restarts Phone. (Resets Wap Settings)
#*2787#
= CRTP ON/OFF.
#*2886#
= AutoAnswer ON/OFF.
#*3737#
= L1 AFC.
#*5133#
= L1 HO Data.
#*7288#
= GPRS Detached/Attached.
#*7287#
= GPRS Attached.
#*7666#
= White Screen.
#*7693#
= Sleep Deactivate/Activate.
#*7284#
= L1 HO Data.
#*2256#
= Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt)
#*2286#
= Databattery.
#*2527#
= GPRS switching set to (Class 4, 8, 9, 10)
#*2679#
= Copycat feature Activa/Deactivate.
#*3940#
= External looptest 9600 bps.
#*4263#
= Handsfree mode Activate/Deactivate.
#*4700#
= Please use function 2637.
#*7352#
= BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF)
#*2558#
= Time ON.
#*3370#
= Same as 4700.
#*3941#
= External looptest 115200 bps
#*5176#
= L1 Sleep.
#*7462#
= SIM Phase.
#*7983#
= Voltage/Freq.
#*7986#
= Voltage.
#*8466#
= Old Time.
#*2255#
= Call Failed.
#*5187#
= L1C2G trace Activate/Deactivate.
#*5376#
= DELETE ALL SMS!!!!.
#*6837#
= Official Software Version: (0003000016000702)
#*7524#
=KCGPRS: (FF FF FF FF FF FF FF FF 07)
#*7562#
= LOCIGPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01)
#*2337#
= Permanent Registration Beep.
#*2474#
= Charging Duration.
#*2834#
= Audio Path. (Handsfree)(marche pas)
#*3270#
= DCS Support Activate/Deactivate.
#*3282#
= Data Activate/Deactivate.
#*3476#
= EGSM Activate/Deactivate.
#*3676#
= FORMAT FLASH VOLUME!!!
#*4760#
= GSM Activate/Deactivate.
#*4864#
= White Screen.
#*5171#
= L1P1.
#*5172#
= L1P2.
#*5173#
= L1P3.
#*7326#
= Accessory.(marche pas)
#*7683#
= Sleep variable.
#*8465#
= Time in L1.
#*2252#
= Current CAL.
#*2836#
= AVDDSS Management Activate/Deactivate.
#*3877#
= Dump of SPY trace.
#*7728#
= RSAV.
#*2677#
= Same as 4700.
#*3728#
= Time 2 Decod.
#*3725#
= B4 last off.
#*7372#
= Resetting the time to DPB variables.
#*7732#
= Packet flow context bit Activate/Deactivate.
#*6833#
= New uplink establishment Activate/Deactivate.
#*3273#
= EGPRS multislot. (Class 4, 8, 9, 10)
#*7722#
= RLC bitmap compression Activate/Deactivate.
#*2351#
= Blinks 1347E201 in RED.
#*4472#
= Hysteresis of serving cell: 3 dB
#*2775#
= Switch to 2 inner speaker.
#*9270#
= Force WBS.
#*7878#
= FirstStartup. (0=NO, 1=YES)
#*3757#
= DSL UART speed set to. (LOW, HIGH)
#*8726#
= Switches USBACM to Normal.
#*8724#
= Switches USBACMto Generator mode.
#*8727#
= Switches USBACM to Slink mode.
#*8725#
= Switches USBACM to Loop-back mode.
#*3838#
= Blinks 3D030300 in RED.
#*2077#
= GPRS Switch.
#*2027#
= GPRS Switch.
#*0227#
= GPRS Switch.
#*0277#
= GPRS Switch.
#*8370#
= Tfs4.0 Test 0.
#*8371#
= Tfs4.0 Test 1.
#*8372#
= Tfs4.0 Test 2.
#*8373#
= Tfs4.0 Test 3.
#*8374#
= Tfs4.0 Test 4.
#*8375#
= Tfs4.0 Test 5.
#*8376#
= Tfs4.0 Test 6.
#*8377#
= Tfs4.0 Test 7.
#*8378#
= Tfs4.0 Test 8.
#*8379#
= Tfs4.0 Test 9.
#*7878#
#*3838#
#*2077# =
GPRS Switch.
#*2027#
= GPRS Switch.
#*0227#
= GPRS Switch.
#*0277#
= GPRS Switch.
#*22671#
= AMR REC START.
#*22672#
= Stop AMR REC. (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673#
= Pause REC.
#*22674#
= Resume REC.
#*22675#
= AMR Playback.
#*22676#
= AMR Stop Play.
#*22677#
= Pause Play.
#*22678#
= Resume Play.
#*77261#
= PCM Rec Req.
#*77262#
= Stop PCM Rec.
#*77263#
= PCM Playback.
#*77264#
= PCM Stop Play.
#*22679#
= AMR Get Time.
*#8999*364#
= Watchdog ON/OFF.
*#8999*427#
= WATCHDOG signal route setup.
*2767*226372#
= Camera Reset. (deletes photos)
*2767*3855#
= E2P Full Reset. hard reset*
*2767*2878#
= E2P Custom Reset.
*2767*927#
= E2P Wap Reset.
*2767*226372#
= E2P Camera Reset.
*2767*688#
= Reset Mobile TV.
*#7263867#
=RAM Dump. (On or Off)
Mar 20 Juil - 08:50 (2010)
Merci à toi Okay
Mar 20 Juil - 09:20 (2010) Visiter le site web du posteur MSN
Et tout ces codes, c'est pour faire quoi après ?! Je n'ai pas compris !! Rolling Eyes
Mar 20 Juil - 10:26 (2010)
A savoir certaine chose comme par exemple la version de ton Firmware, ou encore a faire un RESET du téléphone, etc Wink
Mar 20 Juil - 10:47 (2010) Visiter le site web du posteur MSN
Aaaah d'accord!!! Okay
Merci!
Mar 20 Juil - 10:55 (2010)
comme ça,
vous pourrez tester plus précisément votre phone
Mar 20 Juil - 17:38 (2010)
ungarsduweb
comment ça marche il me marque donnée éroné pour chaque code ?
Dim 1 Aoû - 17:50 (2010)
Sinon le premier code pour le menu admin fonctionne, j'ai édité Wink
Dim 1 Aoû - 18:49 (2010) Visiter le site web du posteur MSN
Lun 2 Aoû - 07:25 (2010)
EAGLEBLAKE37
Slt à tous après avoir trouver ce site je me suis mis a chercher des codes et j en ai trouver mais pas des masse
*#0*# LCD Test
*#03# Unique Number
*#06# Imei
*#78# Admin setting
*#0228# BAT
*#0289# Melody Test
voila si j en trouve d autre je les mettrais a+
Jeu 17 Fév - 12:43 (2011)
pour moi le code pour le menu admin ne marche pas
par contre celui pour la version du firmware fonctionne bien...
Jeu 17 Fév - 16:19 (2011)
 Euh ... 2 minutes de recherches sur SamFirmware ...
Citation:
*#1234# = Firmware Version.
*#2222# = H/W Version.
*#8999*8376263# = All Versions Together.
*#8999*8378# = Test Menu.
*#4777*8665# = GPSR Tool.
*#8999*523# = LCD Brightness.
*#8999*377# = Error Menu.
*#8999*327# = EEP Menu.
*#8999*667# = Debug Mode.
*#92782# = PhoneModel. (Wap)
#*5737425# = JAVA Mode.
*#2255# = Call List.
*#232337# = Bluetooth MAC Adress.
*#5282837# = Java Version.
#*4773# = Incremental Redundancy.
#*7752# = 8 PSK uplink capability bit.
#*7785# = Reset wakeup & RTK timer cariables/variables.
#*7200# = Tone Generator Mute.
#*3888# = BLUETOOTH Test mode.
#*7828# = Task screen.
#*#8377466# = S/W Version & H/W Version.
#*2562# = Restarts Phone.
#*2565# = No Blocking? General Defense.
#*3353# = General Defense, Code Erased.
#*3837# = Phone Hangs on White screen.
#*3849# = Restarts Phone.
#*3851# = Restarts Phone.
#*3876# = Restarts Phone.
#*7222# = Operation Typ: (Class C GSM)
#*7224# = !!! ERROR !!!
#*7252# = Operation Typ: (Class B GPRS)
#*7271# = CMD: (Not Available)
#*7274# = CMD: (Not Available)
#*7337# = Restarts Phone. (Resets Wap Settings)
#*2787# = CRTP ON/OFF.
#*2886# = AutoAnswer ON/OFF.
#*3737# = L1 AFC.
#*5133# = L1 HO Data.
#*7288# = GPRS Detached/Attached.
#*7287# = GPRS Attached.
#*7666# = White Screen.
#*7693# = Sleep Deactivate/Activate.
#*7284# = L1 HO Data.
#*2256# = Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt)
#*2286# = Databattery.
#*2527# = GPRS switching set to (Class 4, 8, 9, 10)
#*2679# = Copycat feature Activa/Deactivate.
#*3940# = External looptest 9600 bps.
#*4263# = Handsfree mode Activate/Deactivate.
#*4700# = Please use function 2637.
#*7352# = BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF)
#*2558# = Time ON.
#*3370# = Same as 4700.
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep.
#*7462# = SIM Phase.
#*7983# = Voltage/Freq.
#*7986# = Voltage.
#*8466# = Old Time.
#*2255# = Call Failed.
#*5187# = L1C2G trace Activate/Deactivate.
#*5376# = DELETE ALL SMS!!!!.
#*6837# = Official Software Version: (0003000016000702)
#*7524# = KCGPRS: (FF FF FF FF FF FF FF FF 07)
#*7562# = LOCI GPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01)
#*2337# = Permanent Registration Beep.
#*2474# = Charging Duration.
#*2834# = Audio Path. (Handsfree)
#*3270# = DCS Support Activate/Deactivate.
#*3282# = Data Activate/Deactivate.
#*3476# = EGSM Activate/Deactivate.
#*3676# = FORMAT FLASH VOLUME!!!
#*4760# = GSM Activate/Deactivate.
#*4864# = White Screen.
#*5171# = L1P1.
#*5172# = L1P2.
#*5173# = L1P3.
#*7326# = Accessory.
#*7683# = Sleep variable.
#*8465# = Time in L1.
#*2252# = Current CAL.
#*2836# = AVDDSS Management Activate/Deactivate.
#*3877# = Dump of SPY trace.
#*7728# = RSAV.
#*2677# = Same as 4700.
#*3728# = Time 2 Decod.
#*3725# = B4 last off.
#*7372# = Resetting the time to DPB variables.
#*7732# = Packet flow context bit Activate/Deactivate.
#*6833# = New uplink establishment Activate/Deactivate.
#*3273# = EGPRS multislot. (Class 4, 8, 9, 10)
#*7722# = RLC bitmap compression Activate/Deactivate.
#*2351# = Blinks 1347E201 in RED.
#*4472# = Hysteresis of serving cell: 3 dB
#*2775# = Switch to 2 inner speaker.
#*9270# = Force WBS.
#*7878# = FirstStartup. (0=NO, 1=YES)
#*3757# = DSL UART speed set to. (LOW, HIGH)
#*8726# = Switches USBACM to Normal.
#*8724# = Switches USBACM to Generator mode.
#*8727# = Switches USBACM to Slink mode.
#*8725# = Switches USBACM to Loop-back mode.
#*3838# = Blinks 3D030300 in RED.
#*2077# = GPRS Switch.
#*2027# = GPRS Switch.
#*0227# = GPRS Switch.
#*0277# = GPRS Switch.
#*8370# = Tfs4.0 Test 0.
#*8371# = Tfs4.0 Test 1.
#*8372# = Tfs4.0 Test 2.
#*8373# = Tfs4.0 Test 3.
#*8374# = Tfs4.0 Test 4.
#*8375# = Tfs4.0 Test 5.
#*8376# = Tfs4.0 Test 6.
#*8377# = Tfs4.0 Test 7.
#*8378# = Tfs4.0 Test 8.
#*8379# = Tfs4.0 Test 9.
#*22671# = AMR REC START.
#*22672# = Stop AMR REC. (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# = Pause REC.
#*22674# = Resume REC.
#*22675# = AMR Playback.
#*22676# = AMR Stop Play.
#*22677# = Pause Play.
#*22678# = Resume Play.
#*77261# = PCM Rec Req.
#*77262# = Stop PCM Rec.
#*77263# = PCM Playback.
#*77264# = PCM Stop Play.
#*22679# = AMR Get Time.
*#8999*364# = Watchdog ON/OFF.
*#8999*427# = WATCHDOG signal route setup.
*2767*226372# = Camera Reset. (deletes photos)
*2767*3855# = E2P Full Reset.
*2767*2878# = E2P Custom Reset.
*2767*927# = E2P Wap Reset.
*2767*226372# = E2P Camera Reset.
*2767*688# = Reset Mobile TV.
#7263867# = RAM Dump. (On or Off)
*2767*43927# = Austria WAP Settings.
*2767*420927# = Czech WAP Settings.
*2767*33927# = France WAP Settings.
*2767*49927# = Germany WAP Settings.
*2767*30927# = Greece WAP Settings.
*2767*39927# = Italy WAP Settings.
*2767*31927# = Netherlands WAP Settings.
*2767*351927# = Portugal WAP Settings.
*2767*7927# = Russia WAP Settings.
*2767*34927# = Spain WAP Settings.
*2767*46927# = Sweden WAP Settings.
*2767*44927# = UK WAP Settings.
*2767*380927# = Ukraine WAP Settings.
*2767*73738927# = WAP Settings Reset.
*2767*43667# = Austria MMS Settings.
*2767*420667# = Czech MMS Settings.
*2767*33667# = France MMS Settings.
*2767*49667# = Germany MMS Settings.
*2767*30667# = Greece MMS Settings.
*2767*39667# = Italy MMS Settings.
*2767*31667# = Netherlands MMS Settings.
*2767*351667# = Portugal MMS Settings.
*2767*7667# = Russia MMS Settings.
*2767*34667# = Spain MMS Settings.
*2767*46667# = Sweden MMS Settings.
*2767*44667# = UK MMS Settings.
*2767*380667# = Ukraine MMS Settings.
#*36245# Turns Email TestMenu on.
*2767*22236245# Email EPP set (....)!
*2767*837836245# Email Test Account!
*2767*29536245# Email Test2 Account!
*2767*036245# Email EPP reset!
*2767*136245# Email EPP set (1)!
*2767*736245# Email EPP set (7)!
*2767*3036245# Email...
*2767*3136245# Email...
*2767*3336245# Email...
*2767*3436245# Email...
*2767*3936245# Email...
*2767*4136245# Email...
*2767*4336245# Email...
*2767*4436245# Email...
*2767*4536245# Email...
*2767*4636245# Email...
*2767*4936245# Email...
*2767*6036245# Email...
*2767*6136245# Email...
*2767*6236245# Email...
*2767*6336245# Email...
*2767*6536245# Email...
*2767*6636245# Email...
*2767*8636245# Email...
*2767*85236245# Email...
*#7465625# = Check the locks.
*7465625*638*Code# = Enables Network lock.
#7465625*638*Code# = Disables Network lock.
*7465625*782*Code# = Enables Subset lock.
#7465625*782*Code# = Disables Subset lock.
*7465625*77*Code# = Enables SP lock.
#7465625*77*Code# = Disables SP lock.
*7465625*27*Code# = Enables CP lock.
#7465625*27*Code# = Disables CP lock.
*7465625*746*Code# = Enables SIM lock.
#7465625*746*Code# = Disables SIM lock.
*7465625*228# = Activa lock ON.
#7465625*228# = Activa lock OFF.
*7465625*28638# = Auto Network lock ON.
#7465625*28638# = Auto Network lock OFF.
*7465625*28782# = Auto subset lock ON.
#7465625*28782# = Auto subset lock OFF.
*7465625*2877# = Auto SP lock ON.
#7465625*2877# = Auto SP lock OFF.
*7465625*2827# = Auto CP lock ON.
#7465625*2827# = Auto CP lock OFF.
*7465625*28746# = Auto SIM lock ON.
#7465625*28746# = Auto SIM lock OFF.
Néanmoins faites très attention avec ces codes, même si certains sont inoffensifs et parfois utiles, ... certains pourraient modifier des paramètres importants et engendrer des instabilités ou des pertes de données ...
Jeu 17 Fév - 20:16 (2011)
Aujourd’hui à 01:25 (2018)
